Deletes an OSPFv3 area or all OSPFv3 areas.
| area_identifier | Specifies an OSPFv3 area, a four-byte, dotted decimal number. |
| all | Specifies all areas. |
N/A.
An OSPFv3 area cannot be deleted if it has an associated interface. Also, area 0.0.0.0 cannot be deleted.
The following command deletes an OSPFv3 area:
delete ospfv3 area 1.2.3.4
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
